So how do you get it back to the start position once it's moved?
What's confusing you about the 90/180 degree setting for the servo? One is "pen up", the other is turned 90 degrees and "pen down". It's in the middle of the range of motion because the ends of the range tend to be a bit "twitchy" and non-linear.
Remember you can change the parameters on the "setup" tab of the controller -
"pen up position", "pen down position" will change those up and down positions. "Test lift range" does a few strokes through the range, and "upload lift range" writes the new range to the arduino - it replaces the 90/180 that you see in the code.
sn
