Hi Sandy, first of all I want to give you a huge thanks for all the work you've done for all of us.
I've put together a polargraph (later on I will document all parts of it for flickr group) and I'm using controller v1.10.6
I am able to draw vector, pen lift works great, pixel rendering is also great (quick timelapse here http://instagram.com/p/y3wFFTGU3C/ ) but everything on roving tab fails.
I tried following this write up
http://www.polargraph.co.uk/2012/08/norwegian-pixel/
I assume "set roving area" in step 4 is the same as "Send Roving Area" that I'm seeing in gui. When I click on it I get an error, mentioning unknown w1.pbm and then if I try to proceed with other steps, it can't seem to load my image file. I've treid "C:\lab01.pbm" as an image file name, with and without quotation marks. I'm saving greyscale PBMs from photoshop. You can see queue output in attached screenshot
Probably worth mentioning that I can't seem to locate sprites for text and was never able to figure out text rendering as well. I tried looking through source code to figure out if it assumes a specific folder as root for all images, but didn't find anything there.
Might be a stupid question, but was this only meant to work with polargraphSD ?
