I have unsuccessfully tried making so I can connect to a micro USB for the last day.
To try and narrow down the problem I copied the SD connect code into an empty Arduino project like so.
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
bool cardPresent = false;
bool cardInit = false;
File root;
void setup()
// Open serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
pinMode(chipSelect, OUTPUT); // necessary for SD card reading to work
// see if the card is present and can be initialized:
int initValue = 0;
initValue = SD.begin(chipSelect);
if (initValue == 0) {
Serial.println("Card failed, or not present");
else {
Serial.println("Successfully beginned.");
cardPresent = true;
if (cardPresent) {
Serial.println("card initialized.");
root = SD.open("/", FILE_READ);
cardInit = true;
Serial.println("done!");
void loop(){
This works fine and prints the following message to the Serial.
card initialized
done!
However, this exact same code in the main code (The polagraph one) DOES not work and I get the following message.
Does anybody have the same problem? Am I doing something wrong?
